Overheating GPU please help
Vicky555
159
Hello Friends I have Nvidia Geforce GTX650Ti 2GB Gainward .. My GPU is overheating as when ever I start my PC its on 35 degree Celsius .. And When I play games its on 65 or 69 degree Celsius.. Will this temperature melt my GPU or blow it or both?
My PC Specs:
i5 3450
8Gb ram(corsair)
Asus Mobo.
iBall 500watts PSU
I don't have any water cooling system or any other cooling system ..
I only have stock cooler And tell me the best place to fit the fans.
And what if I play games on highest settings will temperature rises and what if I play games on lowest settings will temperature decreases. ?
^ Agree. Download MSI Afterburner and you can modify your fan profile so that they are ramp up sooner and spin faster. You can monitor your temps and see if that makes a difference.
-Bruce
It means 70 is normal and what if it goes up to 70 ?
Doesn't decrease the life of fan?
Nope you just need MSI Afterburner to control the fan speed and temperatures shall vary accordingly
Sure the life of the fan may decrease slightly if you game all the time. MSI Afterburner adjust the fan output dependent on gpu temp and what you set for your fan profile. If you are web browsing the gpu load will be light and the fans will not spin fast.
-Bruce
Can I use EVGA Precision X
