Hi all,
Current gaming PC build:
Asus P8Z68 with i5 2500k @3.3 Turbo at 4.0Ghz (Coolermaster sink)
8g Ram
Nvidia Geforce 960ti
SSD 250gig boot drive.
I've had no real issues with this build and only upgraded the graphics card from a 560 to a 960 in the last year (a 970 would have been preferable but cost considerations kicked in).
I recently tried a 4.5 overclock which seemed stable but sent CPU temps through the roof. Turbo to 4.0ghz seems better.
Temp wise on idle everything is good around 36 degrees. However, have noticed recently since picking up the Division that CPU temps are up in the 76-86degree range and steady. This seems like it is running too hot? (I have the Division on High settings and runs beautifully but appreciate it is also resource intensive). Other games seem to not be having this issue and all around 50-60 degree mark
I've also been considering whether its time to do a CPU/mobo/ram upgrade to new skylake i5-6600k but other than the improvements in chipset you get from new z170 boards there doesnt appear to be a huge performance increase.
So my really my questions are:
- How concerning is the overheating CPU? Sink appears set fine and idle temps are good. would a bigger better cooler be an option?
- Is it worth upgrading cpu/mobo? Or would a GPU upgrade be more benefit?
- Where are my potential bottlenecks for playing at high settings and decent framerate.
Thanks for any help apologies if anything isnt clear I' working nights at the moment and brain is mush!
8g Ram
