OverHeating issues in CPU while on load
Sep 23, 2018
6
I have an intel(R) core i7-6700HQ CPU @ 2.60GHz and GTX 950m 4gb. I used to game a lot on this laptop and stopped due to this problem , whenever my CPU is on load its temp is quickly raised to 86C and after few sec to 95-98C . I have cleaned my laptop , changed thermal paste , resinstalled bios , reinstalled OS . When ever i run a test on OCCT for CPU it automatically stops after 15-20 sec due to the temp values above 95C .
OCCT test cant run to its complete - https://imgur.com/a/Yrmqbwu
5 sec after i stress my cpu by CPU-z - https://imgur.com/a/ZmylpFc
I havent overclocked my cpu or gpu .
Pease help me , Sorry for my bad English .
Not necessarily a faulty fan, but everything in laptops are tightly squeezed together. You bring it around, it gets bumped, hardware constantly getting exterior pressure from movement. Usually the first one that goes out after the battery are the fans, specially gaming laptops. Could be worth changing them. It'll cost you around 10$.
Although the best thing would be to bring it to a service center. They will be able to tell you more. for sure.
This might sound stupid, but are all your drivers (including your GPU drivers) updated to its latest version? Did you use Nvidia GeForece Experience? Is the Bios also on its latest version.
At this point, I think it safe to say that the cooler is worn out, you might consider getting new fans.
