Overheating Problems i7-4790k
studerman1
32
Using h100i max pump and fan speed
Idle temps 32-38
Use prime 95 for half a second and they all max to 100c
Running at 4400Mhz
Is there a problem with my h100i?
Its been one year almost to the day and its the first and only one on this cpu
Okay I will do first thing tomorrow and get back to you
Wuf3If5
Yes and it says the pump is running fine
I just replaced the thermal paste and noticed a 9-degree drop at idle I was break it in soon and update. I remember adding more than enough about a year ago but The thermal paste was only covering about 75% of the cpu
Do the fans and your pump RPM's increase when your temps rise like that?
Also are you controlling your voltage in the BIOS with Auto, Adaptive, Offset, or Manual?
When running AVX loads (like Prime 95 Small FFT's), the first three options above will seriously overvolt your CPU. It is recommended while stress testing AVX intensive software to use Manual which will keep your Vcore at a static voltage. Adaptive and Offset can raise your Vcore by as much as 10mV (.01V) from the normal load Vcore when placed under an AVX load.
Adaptive, Offset, and Auto (which defaults to one of the first two), is fine for day to day use. It's just while using Prime 95 that you should consider Manual.
Read this thread:http://www.tomshardware.com/answers/id-2215787/prime95-temps-high-4790k.html
All credit goes to CompuTronix.
Link no longer is there but I will give it a try
