Question Overheating until I remove side panel
Jun 15, 2019
23
Hello there.
I am currently using a Zalman Z1 Neo, and I was completely satisfied about it, when this happened:
The case was super hot (the cpu was 80+C while playing overwatch and other games like that) , so i removed the side of it and the cpu had 60-70 C.
So, does it worth it if I remove the side panel and play without it? ( I don't really plan dusting it every single week/day)
What's your cpu cooler?
I've seen a video where a russian guy says that this case is like an oven.
You probably could play without the side panel , clean your room from dust , open your window for extra room cooling xd
