News Overseas Ryzen 9000 CPU preorders shed light on potential MSRPs — Ryzen 9 9950X for $707, Ryzen 5 9600X for $332
9600x is only 65w but not included with warith cooler on the box. And it down colcked from 4,7GHz 7600x base clock to only 3,9 GHz 9600x. So i still wait ryzen 5 9600 ( whithout X model) which is cheaper and included the wraith cooler in the box for my office.
I would suggest waiting for the new products to launch and be reviewed before you make your decision as to what to buy because the moment the new line of CPU's are available to buy the Zen 4 line will drop in price, and which option is best for you is going to be dependent on your use case/need, future considerations, price, and value.
There will also be a change of motherboard pricing as the new boards roll in sometime around the beginning of September, but that might not line up with your buying options.
In a similar way, RAM may also be effected as some people who just bought a new 9000 series CPU might also buy fast RAM, which in turn pushes down the price of everything below it, but I wouldn't expect this to make much if any price difference but with the upcoming reviews it would make you better informed as to what RAM to buy for your 7000 / 9000 CPU for this office machine, but note that RAM reviews that hone in on price/performance / value don't typically come out for a week or more.
I hope this info helps your buying choices / plan.
Reactions: iLoveThe80s
IMO, AMD needs to rein in pricing even a bit more, and especially on the low end. 250 is the max I would pay for a 6c/12t CPU right now and this is because Intel is likely going to have 1X700k available for the same price or less. If the 9600x is not faster in at least gaming than the prior mentioned Intel CPUs, this will be considered a bad impression by AMD for me. the 9700x being at 400 instead of 450 is a nice reduction in MSRP, however, its the same story as the 9600x. It better at least match the 1X700k Intel CPUs in single AND multithreaded for 400 dollars, otherwise I think it should be much closer to 330-350 max. The 9900x IMO retaining its 500 dollar MSRP is a slap in the face most likely. 450 is the max I would pay for 12c/24t with aforementioned 1X700k and 1X900k CPUs being either price comparable or as little as 1/2 that cost. the 9950x is the only more reasonable MSRPed part here at 700. 650 would have been nice but there is less competition at this performance tier from Intel, not that it is not close though!
I hope that I am instead blow away at the benchmarks to come and that all the CPUs are worth it even considering their MSRPs. I also hope these AMD CPUs blow Intel's current offerings out of the water, because if they don't, a reckoning may be coming with the upcoming Intel CPUs. A strong showing from AMD means higher competition from Intel, which has been waning from AMD in the last few years in non-gaming performance.
Reactions: KyaraM
People who still buy Intel are hopeless. If it wasn't ZEN Intel would still be releasing 1900s CPUs with minimal if any upgrade year after year and charging even more than they are now. Not only AMD pushed the industry back to the tracks it already surpassed Intel for some time. Intel can't beat X3D gaming, can't beat X950 value for productivity, can't beat ThreadRipper at server front. That's what they deserve alright, unfortunately they are still laying around because of the die hard goo supporters
The 14700k is 410$. You can get a Ryzen 7800x3D for cheaper. If you want to compare Intel to AMD then at least compare them in a fair way.
Furthermore, you're currently making basless assumptions about both Intel's and AMD's next gen performance. At least wait for them to release before bashing AMD.
Did it though? Regarding the desktop cpus performance increase at a given price were much bigger back when intel was dominant. I know it sounds absurd but do the math. Between 2012 and 2017 we have a much bigger gain with intel at the 330$ mark than we have from 2017 to 2022 with amd. Heck, they reduced the amount of cores at 300$ from 8 to 6, lol
AMD will be much more competitive this gen than they were the previous two in terms of Mt performance. Due to the removal of HT mainly. Yes intel will still be faster in most segments but it won't be that big a gap like it was the last 2 generations.
If amd achieves better efficiency at iso power, that will be impressive, but that's really hard to achieve due to the lack of cores.
Reactions: helper800
I am not making baseless accusations on any side, and I also clearly state that this was opinion and that testing may completely change my mind. I appropriately hedged everything I said.
While I can see AMD being par with Intel in most things this generation we cannot know until the benchmarks come out. I am cautiously optimistic that this will be one of the most competitive generations in a while.
The biggest problem I have is that - it isn't amd that's getting better in the areas they are lacking (MT performance at - below the 400$ mark), it's just Intel (theoretically, we need to see reviews) are getting worse by removing HT. AMD will still remain lackluster. I fully expect the brand new shiny R7 8700x to be getting absolutely annihilated by the 2-3 generations old i7 13700k.
Why is this allowed and how the heck do people end up buying this products is beyond me, but here we are.
