I've been looking at the design of the PSU and case I want (Antec P180 and Seasonic S12 600W PSU). However I noticed that the PSU's intake for air is in the top/bottom (depending which way up you have it) and not on the opposite side to the cable and therefore the airflow is not straight through.
Having looked at the case online it doesn't look like there is hugh amounts of space for the air to circulate around the PSU and am concerned that these two in conjunction will make more noise as the fans will probably running faster to keep things cool enough and forcing air around the sides of the PSU rather than some of it through it may also generate more noise.
Thoughts please? has anyone got this combination already or for that matter any PSU in the P180 that has the same design? Is this a problem?
Any help most appreciated.
CC
CC
