P4 CPU running too hot
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Indicators show my new P4 2.80C running around 60C/141F and the system
temp at about 41C/105F. This is hotter than my previous setups have
run, including the P4 2.4 I replaced. I'm using the retail package
heatsink/fan with the included thermal pad.
Assuming the mobo software (MSI 865PE Neo2-P) is reporting correctly,
what can I do to get the CPU down to the mid 40s C? Any suggestions
for adequate heatsink/fan combos? Also, is a fan suggested for the
chipset?
I may want to OC at some point, but there's no way I'd consider that
unless I can get the temps down.
TIA!
Larc
§§§ - Change planet to earth to reply by email - §§§
G
Guest
Guest
Try cleaning the pad off of the cpu with isopropol alcohol (or finger nail
polish remover) and a lint free rag or a coffee filter. and use something
like Artic Sliver5 thermal paste instead.
Instructions here on how to apply it ->
http://www.arcticsilver.com/arctic_silver_instructions.htm
"Larc" <larc-news@jupiterlink.net> wrote in message
news:l7nb70549482dnmtv4vt2krof65ublnfsd@4ax.com...
> chipset?
> TIA!
> Larc
G
Guest
Guest
If the case is at or near 41C, your room must be quite warm to start off
with. Your case needs airflow. Minimum of one 80mm front intake and one 80mm
rear exhaust.
G
Guest
Guest
| rear exhaust.
2 front 80mm and 1 rear. The room is currently 74F (23.3C).
I just learned there are some issues with the mobo and its temp
reporting. A recent BIOS update that was supposed to cure the problem
evidently didn't for everybody.
Larc
G
Guest
Guest
On Thu, 8 Apr 2004 18:46:12 -0500, "BigStan"
Although I've learned the mobo may be misreporting temps, I'll
probably do that anyway. This is my first CPU in a long time with the
supplied thermal pad.
Larc
G
Guest
Guest
That's sounds reasonable. Load the CPU to 100% and see if it produces any
errors or throttles down.
G
Guest
Guest
>chipset?
This is normally a cool chip. The stock Intel HS-fan works great, and keeps
mine very cool.
You have 1 of 3 problems:
**Your computer case is trapped in dead air, such as a cubby hole in a desk.
The case needs to be out in the open, and the exhaust fans not blocked.
**Your Heat Sink is not making full contact with the chip... it's tilted or
cocked. (not likely with the brutal P4 HS-fan clamping system)
**The temp is being mis-reported. Simply put your finger on the top of the
case. If it's cool, then put your finger on the HS. The HS should feel
pretty darn hot at 140F. If the HS is only lukewarm, your chip is lying
about the temp.
Bob
Remove "kins" from address to reply.
G
Guest
Guest
news:vn3c701h83lvuv2ud4v8v077t11o233oof@4ax.com...
nail
something
> Larc
That's a good idea anyway... Also you might want to try MotherboardMonitor 5
to see if it reports anything different, although it might not, if its a
bios issue. But its a great prog anyway.
Good Luck!
BB
