P4 power swap
G
Guest
Guest
Is the power supply for the P4 different than for the P3? What about the case itself, can you just swap p/s?
May Poseidon cast a fair glimpse on your Odyssey.
Crashman
Polypheme
Editor
Asus makes a P4 motherboard that can use a standard power supply. The heatsink for the P4 bolts to the motherboard. There are new cases which support this feature, or you should be able to make an old one work.
Cast not thine pearls before the swine
G
Guest
Guest
So the answer is yes?
Crashman
Polypheme
Editor
Yes? OK yes, the power supply is NORMALLY different, but the Asus motherboard can accept EITHER the special or the standard power supply. Yes, you can use a normal case.
