Well i built my pc about 4-6 months ago and it has been running fine .. little warm but still no problems .. last night when i was playing a game .. my computer starting beeping which i looked at the temp and it was at 80Cso i shut the computer down and checked the fans and everything.. everything was running good .. so i started it back up .. same thing .. runs 50-55C idle .. then 75+ playing a game .. so i said screw it ill take the heatsink and fan off and put new compound and stuff in it .. took the cpu out .. and it slipped out of my hand i got it before it hit the floor lol but my fingers touch the bottom of the cpu and had a finger print on it .. so for some damn reason i get 99% alcohol and a Q-tip and remove the fingerprint any way i put it back in .. put the compound on it .. and fan and heatsink .. went to turn pc on .. all lights and fans work .. but nothing on the screen then it shuts off after about 20 seconds .. then i redid the compound and fan again .. it booted ..showed bios and everything .. then 10 seconds or less it shut down .. so i turned it back on .. nothing comes on the screen but fans and lights work .. so what i wanna know is .. me touching the cpu .. and using alcohol on it .. could i of fried it ? 🙁
