P4 retail box thermal material?
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
When I opened the box, I found a black piece of tape or whatever on the
bottom of the heat sink. Is that part of the thermal material or should
I remove it?
I've also looked at Intel's site and downloaded a pdf on the thermal
management and fitting, but found no instructions to remove the tape.
Furthermore, Scott Muellers book mention that the thermal material may
be either paste, pad or tape.
There is also a reference in the motherboard manual to "thermal tape".
G
Guest
Guest
the
should
> I remove it?
Leave it on.
Stacey
1,760
> I remove it?
Some come with "protective tape" over the thermal pad to protect it in
shipping. The instructions that come with the CPU should explain this in
detail. If this "tape" you're talking about is a small square then this is
probably just the thermal pad, leave it alone and just install it. If it's
a piece of tape that goes over to the edge of the HS, it's probably a piece
of tape to protect the pad. It should be pretty obvious if it's the
protective kind of tape. Good thing with a P4, if you screw up this part,
the chip just throttles itself back instead of burning up.
Stacey
G
Guest
Guest
In article <2hv9n7Fgt4viU2@uni-berlin.de>, fotocord@yahoo.com
says...
> > I remove it?
The Retail Opterons come with a hard plastic sheet over the
bottom of the fansink to protect the goo. Seems to be an
excellent solution.
The P4 throttles in any case. ;-)
Keith
G
Guest
Guest
"KR Williams" <krw@att.biz> wrote in message
That's still better than just turning. ;-) ;-) ;-) ;-) ;-) ;-) ;-) ;-)
G
Guest
Guest
Oops
"Anthony Fremont"
That's still better than just turning OFF. ;-) ;-) ;-) ;-) ;-) ;-)
G
Guest
Guest
In article <vZuuc.36137$lY2.20474@fe1.texas.rr.com>,
spam@anywhere.com says...
> Oops
> "Anthony Fremont"
You really ought to get with the 21st century, AF. P4 is dead.
*dead*, *DEAD*, I tell you! ...just as I predicted some few
years ago. ;-)
Keith
G
Guest
Guest
I've been working on demonstrating/testing just this.
What leads you to this conclusion?
-- Robert author `cpuburn` http://pages.sbcglobal.net/redelm
G
Guest
Guest
news:MPG.1b2446e99325b56398992e@news1.news.adelphia.net...
> > Oops
> > "Anthony Fremont"
> years ago. ;-)
Give it up Keith, Intel rules. Just go on over to Tom's Hardware and
see for yourself. ;-)
G
Guest
Guest
In article <ulvuc.36141$lY2.21335@fe1.texas.rr.com>,
> > > Oops
> > > "Anthony Fremont"
> > years ago. ;-)
Hogwash! Opteron rulz. P4 is dead, *dead*, DEAD*! Intel got
caught with their panties soiled, once again. Now, if I can get
the last 10' of the cable from the upstairs bedroom to the wiring
"closet" tomorrow... Then there is Linux to figr out.
Keith
G
Guest
Guest
and
Nah, you're fantasizing again, HT is king. ;-)
> Now, if I can get
It's about time you got with the program (Linux that is). Which flavor
will you be using? I highly recommend Gentoo (www.gentoo.org) for the
long haul. Of course if you really wish to get your hands dirty, you
may want to do an LFS (www.linuxfromscratch.org) install just for grins.
G
Guest
Guest
In article <4yCuc.20475$4x2.15776@fe2.texas.rr.com>,
> and
HT is dead, *dead*, *DEAD*! (well, until the next attempt, anyway
;) and P4 has been canceled. ;-)
> > Now, if I can get
> will you be using?
SuSE 9.1
I'm not a programmer type. I want a system that works, rather
than one I have to keep fiddling with. Though I may install
something else in another partition for play. I'm dumping Win
because of it's licensing/registration/security (read that both
ways) issues, not because I want to fiddle with the OS all day. I
went with SuSE because I believe it has better AMD64 support. ;-)
I installed SuSE late yesterday, but the monitor doesn't work
(H.V refresh too high) after installation. It also complained
about some other things (like no Internet found), so I'll retry
after I get the last 10' of the pipe finished, likely this
afternoon.
Keith
G
Guest
Guest
> and
> > Now, if I can get
Thanks folks, didn't imagine that I would start a long thread. Found this
however:
http://support.intel.com/support/processors/sb/cs-005969-prd24.htm
This should clear up the matter; I'll leave the black strip on.
Done is done, I did also consider AMD but got a P4C 2.8/800. My choice
however, was motivated by the Intel's dual channel memory and 800 fsb.
I think this is more important than small differences in GHz. Notice
that I picked the lowest GHz in currently available in this family.
AMD also have dual channel versions, but that's the 940 socket family
which costs more. Once this computer is up, I'll hardly notice the
innards. Whatever you buy it will be obsolete tomorrow, but then I have
work to do.
G
Guest
Guest
In article <40BB215B.122D5C60@sizefitter_spam_gets_fried.com>,
johs@sizefitter_spam_gets_fried.com says...
> > and
> > > Now, if I can get
> however:
> work to do.
A little more $$, sure. I decided add the $$ (go bare-bones
elsewhere, for now) and skip the K7 family altogether. Note that
AMD not only has dual-channel, but an integrated memory
controller. Intel has to stuff memory accesses through the
northbridge and system bus.
Keith
G
Guest
Guest
No way, AMD will HAVE to implement multi-threading in some fashion
sooner or later. Prolly later, like usual. ;-) BTW, Intel is coming
out with their 64bit P4 in August AIUI.
> > > Now, if I can get
flavor
> > will you be using?
> SuSE 9.1
I've never installed SuSE, couldn't get past all that german. ;-) I
started with Slackware in 1995, also done a few Redhat installs, an LFS,
played with Knoppix, and completed a bunch of Gentoo setups. I now
strictly use Gentoo for customer server setups. Installing or updating
packages in Gentoo is way too easy.
you
grins.
Then install Gentoo. I'm serious, it's a piece of cake. Emerge is the
greatest thing since sliced bread. Just follow the step by step
instructions to bootstrap your way up and then afterwards you'll know
what you need to know to manage your system.
Yeah, MS is clueless. But thanks to spyware, addware and virii, I keep
myself pretty busy. ;-)
I really don't see how any one distribution can have better support, the
kernel is the kernel is the..... The nice thing about Gentoo is that
you can compile everything (kernel, libs, and apps) optimized for your
CPU. The downside of that is you can't simply stick your hard-drive in
another box (unless it's the same arch of course).
Post your XF86Config file and let me see what they've mangled in it.
;-) It could be that your monitor lied to the X server about its
capabilities. It happens. Getting things like 3D acceleration to work
can be a pain. Most Linux install problems are due to greedy
manufacturers not supporting it and demanding NDA's before releasing
hardware details. Once manufacturers get with the program, Linux should
run away with the market since developers will be able to concentrate on
the kernel and apps instead of spending all their time reverse
engineering braindead hardware to create drivers. ;-)
> afternoon.
Yeah, that last 10' can be a real bitch.
G
Guest
Guest
In article <Z2Iuc.20517$4x2.6768@fe2.texas.rr.com>,
Seriously, multi-core chips are the next thing. HT isn't all
that big of a win, at least as implemented.
> > > > Now, if I can get
> flavor
> > > will you be using?
> > SuSE 9.1
No German. SuSE is owned by Novell.
> you
> grins.
I was specifically warned away from Gentoo but a colleague. BTW,
he thought my choice of SuSE was the right one too (he uses
Gentoo).
Dunno, but SuSE is considered a front-runner in 64bit support.
Port/compile/test with 64b? Dunno, I'm only going by what I've
read.
> can be a pain.
You're likely right, though I didn't have the energy to dig
through it last night. No 3D here. It's a pretty stock monitor
graphics card setup (ViewSonic P95f + Matrox G550). I'll likely
try it again after I move this machine upstairs (so I can go dual
head).
SuSE claims to have been tested ("supports") the G550.
> > afternoon.
Actually it's not bad, but RG-6 doesn't stretch that much. ;-)
The hard part was the first 10' (through a wall between the
dining room and family room up to the upstairs. This is just
drilling down from the electrical closet (outside shed, sort of
thing) to the basement (done). Next, a(nother) trip to the Home
Despot for some 'F' and RJ45 parts. I thought I had everything,
but I can't find 'em. :-(
Keith
G
Guest
Guest
I like the idea of HT, it seems like a decent way to get some extra
performance for a small transistor cost. However I'm not sure if it's
really a big win. It certainly isn't for all cases, though I have
seen some places where it bumps performance up by 20-25%. That's
pretty respectable IMO.
That being said, I'm REAL excited about future dual-core chips. I'm
thinking that I'm going to ride my current system out until they
arrive and upgrade then. I've got an AthlonXP 1700+ that is serving
me pretty well, though some games are occasionally a bit slow and
compiling stuff in Gentoo is slow as always.
They may be owned by Novell, but it's still pretty much a German
thing. That being said, all the important scripts and instructions
seem to have been well translated into English last time I looked into
it (pre-Novell buyout).
>Gentoo).
As another user of Gentoo, I would also warn away from it. Gentoo is
great for people who live and breath Linux as well as those who just
like to play around with it. However, if you want a system that
pretty much just works out of the box, it's not a very good choice.
>read.
SuSE was the first to get their 64-bit system really up to par. From
what I understand, these days RedHat, Gentoo and Mandrake (and maybe a
few others) are all doing just fine with 64-bits as well. The 64-bit
part itself was pretty straight-forward, most distributions already
support some 64-bit architecture in some for or another (mostly old
Alpha and/or SPARC, though some also support PPC 64-bit). Mostly it
was just a straight recompile. The only tricky part was the bi-arch
nature of AMD64 systems, getting them to work well with 32-bit x86
binaries as well as the 64-bit x64-64 ones.
Tony Hill
hilla <underscore> 20 <at> yahoo <dot> ca
G
Guest
Guest
>> I remove it?
>shipping.
P4's don't, in my experience.
G
Guest
Guest
>> Oops
>> "Anthony Fremont"
>years ago. ;-)
I think you predicted the same for USB, though... 8)
G
Guest
Guest
Crikey. Neither one of these is for the Linux neophite, eh? I've
been playing with Fedora core 2 and I like it.
G
Guest
Guest
>controller.
AMD has dual channel for huge $$$, yes. Although it's also true that
the Athlon doesn't have the thirst for bandwidth that the P$ does...
G
Guest
Guest
I agree. It's obviously not as good as two CPU's, but it's also much
cheaper than two CPU's.
>(snip)
Agreed. ALSO, anyone considering trying one of the new Linux's should
be aware of a problem they have with dual-boot systems - that is, they
don't work, as I learned the hard way 8(. I had Win2k, and
installed Fedora on my secondary drive (installing Grub as my
boot-loader), and Win2k would no longer boot.
G
Guest
Guest
In article <2g5nb097hh3ggl1en5vm7rdkhgm9k1m3lj@4ax.com>,
hilla_nospam_20@yahoo.ca says...
Wunnerful ideas don't always translate into great products. The
P4 is a perfect example. Wunnerfull, but not great.
I skipped the K7 generation totally. My K6 still works tonight,
thanks to a KVM. ;-) Games? Please! Perhaps something
interesting, but I don't do 3D-shoot-em-ups. I've not seen a
reason to go 3D. I've seen *many* to do excellent 2D though.
Have you looked at 9.1? I'm still wondering about the warning
message that I'm installing a 32bit OS on a 64bit machine.
though. I want to start over, but it seems to be adamant that it
knows better. ...perhaps that "German" thing? ;-)
> >Gentoo).
That's what I've been told (obviously), by one who frequents both
my office and this group. ;-)
> >read.
Hmmm. Is this why I'm getting the above *stupid* message? I do
plan on reformatting everything and starting over. I still have
this machine, at least until I get the CFO to buy into Linux.
Keith
G
Guest
Guest
In article <iauob09t7vnqpel3ond50710qdmfqd6gqi@4ax.com>,
chrisv@nospam.invalid says...
> >> Oops
> >> "Anthony Fremont"
> >years ago. ;-)
Yeah, I was never a fan of USB and have only recently bought any
USB widgets (a still camera and printer, still in its box). How
long did it take for USB to become usable? It's only in it's
later incarnations is it even useful. If you remember my
proposal was to simply use Ethernet for low speed connections
(the infrastructure was already there) and Fire-Wire for the
high end. Though apparently Apple mucked the latter possibility
possibility up.
Keith
G
Guest
Guest
On Tue, 01 Jun 2004 07:44:52 -0500, chrisv <chrisv@nospam.invalid>
>>controller.
Not quite so huge, the 1xx series of Opteron chips are actually rather
reasonably priced (I was quite surprised the last time I checked).
They start at only a bit over $150 and even the some of the faster 146
(1.8GHz) chips can be found for under $500. Expensive, yes, but in
the same basic range as high-end P4 chips.
Also, AMD just today announced their socket 939 Athlon64 chips which
should bring dual-channel Athlon64s to the masses. (amazingly enough
you can actually BUY the chips today too! albeit for a
first-on-the-block premium).
Tony Hill
