Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
In article <c9ppjv$r34$1@sparta.btinternet.com>, "MC"
<maxcoppin@-don't-send-me-any-spam-btinternet.com> wrote:
> Hi,
> Has anyone connected up the front pannel audion header on the P4C800? What
> effect does it have on the rear connections? I know there's a jumper over
> some of the pins at the moment so what happens when you hook it up? Is it
> possible to plug speakers in the back and then override this with headphones
> in the front?
> One other question - I have the following connenctions on my front pannel:-
> line out:
> earo-r (red)
> earo-l (white)
> reserved (black)
> Microphone:
> line out:
> micout (red)
> micin (white)
> agmd (black)
> How do these match up to the connections on the P4C800?
> Thanks guys!
> MC
Your earo-r and earo-l go to the Line_out pins.
There is only one ground on the Asus header, so you
might need to use a ground pin on a USB header, for
example, if you need a second one. Sometimes the
lineout and microphone jack grounds are shorted
together inside the case, and only one of the two
grounds need to be connected. As for the micout
and micin, that is a strange terminology. The signal
from the microphone is on the "tip" of a 1/8" stereo
plug, and microphone power is on the middle contact
of the stereo plug called "ring". You have to figure
out how micin and micout correspond to those two
signals on a stereo plug.
"MIC Input Characteristics"
http://www.a-tech.net/SoundCards/CT4811.htm
MIC2 ------| | <--- Tip
MICPWR -----| | 3.5mm plug <--- Ring
|===| to soundcard
GND -------| | <--- Sleeve
Here is how the loopback function works -
************** No jack - factory default jumpers in place ********
FP_AUDIO
MIC2 X X AGND
MICPWR X X +5VA
Line_out_R X<-->X BLINE_OUT_R
NC X
Line_out_L X<-->X BLINE_OUT_L
----------| Sound |
| | Chip |
FP_AUDIO | |
Jumpers | | Lime Lineout (Back)
Line_out_R ^-------| |
| | AGND ------+ (SLEEVE)
BLINE_OUT_R v--------- | -----------+ (RING)
BLINE_OUT_L ^---------- | ---------+ (TIP)
Line_out_L v-----------|
*************** Good jack with Computer Case ********************
----------| Sound |
| | Chip |
Case Front Audio | | -------------
("Interrupting" Type Jack) | |
-------- 1 AGND | | Lime Lineout (Back)
| ______ 2 Line_out_R <---| |
- -| / ^ | AGND ------+ (SLEEVE)
| | |--- 3 BLINE_OUT_R ----- | ----------+ (RING)
| | |--- 4 BLINE_OUT_L ----- | --------+ (TIP)
| | v |
- -| \_____ 5 Line_out_L <-------|
*********** Bad jack - sound only works on front of case *********
----------| Sound |
| | Chip |
( "Non-Interrupting" Type Jack) | |
- -| / | AGND ------+ (SLEEVE)
| | | ??? -------+ (RING)
| | | ??? ------+ (TIP)
Your case has the bad jack, without the loopback connections
for BLINE_OUT_R and BLINE_OUT_L.
HTH,
Paul
