Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
In article <10ao2dnm6cn4g93@corp.supernews.com>, "Dean Slindee"
<slindee@charter.net> wrote:
> Assume I have a P4P800 mb and 2GB of PC2700 DDR 333 memory. What 3.n+ GHz
> Intel CPU's can I run with this combination? Will an Intel P4 3.06GHz FSB533
> work? How about an Intel P4 3.0GHz FSB800?
> Thanks,
> Dean Slindee
Download the manual from the Asus web site, and you are likely
to find a table like this:
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200/PC2700*/PC2100 400/333*/266 MHz
533 MHz PC2700/PC2100 333/266 MHz
400 MHz PC2100 266 MHz
*When using 800MHz CPU FSB, PC2700 DDR DIMMs may run only at
320MHz (not 333MHz) due to chipset limitation.
According to that table, three different speed settings for
memory are allowed with FSB800 processors. Two different
speed settings are allowed with FSB533 processors.
Always download the manual for a board before you buy, as the
contents of the manual are your guarantee of how the board
works. Check the BIOS features carefully, to see if the
adjustments you need are there. Even if you aren't an overclocker,
adjustments are still handy for figuring out why your system
isn't working the way you would like. A lot of the microATX
boards lack any useful adjustment, and all you can do is just
stare at your build and twiddle your thumbs, when something
isn't working right.
HTH,
Paul
