P4P800-X power LED
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I just upgraded to the P4P800-X & I would like to know why the power LED
on the front of the case is lit when I turn off the computer. I have the
"power button mode" set to "on/off" & "Restore on AC power loss" set to
"power off" in the BIOS. I also have usb jumpers set to +5v. I have
double checked all connections & everything looks good. Is this
something new to ASUS boards to let you know the computer is still
plugged in. I thought that was the purpose of the SB LED on the mobo itself?
Thanks for any insight on this.
> itself?
Hooking up the LED lights is sometimes tricky, esp. in tight
spaces. Placed the Power LED header across the right pins? And
the right LED, i.e., the header is 1-X-3, where X=empty.
GHalleck wrote:
>> LED on the front of the case is lit when I turn off the computer. I
>> have the "power button mode" set to "on/off" & "Restore on AC power
>> loss" set to "power off" in the BIOS. I also have usb jumpers set to
>> +5v. I have double checked all connections & everything looks good. Is
>> this something new to ASUS boards to let you know the computer is
>> still plugged in. I thought that was the purpose of the SB LED on the
>> mobo itself?
Yes it is connected correctly. I even went as far as disconnecting
everything (PCI cards, AGP card, drives, memory, all other front panel
connectors & USB devices) from the mobo except main power supply & the
power LED. It still lights up with the SB LED on the mobo when the
computer is off.
I finally had some time to checked out the Asus web site & I found that
my problem was the BIOS needed to be updated to at least ver 1005 to
correct the power LED problem, my board came with 1003. I updated the
BIOS to 1008 & my power LED works the way it is supposed to.
>>> Is this something new to ASUS boards to let you know the computer is
>>> mobo itself?
> computer is off.
