G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I purchased an ASUS P5AD2 Premium Motherboard with a new P4 3.2 CPU.
I tried to assemple my system yesterday, however the motherboard can
not find my hard drives.
I have connected my CD-ROM and DVD-ROM through the primary IDE port
right next to the Floppy IDE, and since this motherboard has two more
IDE ports, I connected my hard drives (I Have 2) to the the other one,
using cable select.
however when I tried to install Windows XP on the system, I recieved a
message that says:"No hard disk found on the system."
I am guessing that for some reason either both of the other IDE ports
are bad or there has to be a setting that needs to be changhed.
I was also wondering that maybe the RAID setting is what is causing it,
but aftrer reading the user manual, I found out that all the ports are
set to IDE by defualt.
Can some one tell me what is wrong here?
using cable select.
