p5gd1: big problem with USB, please help!
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
hi to all
i have a serious problem and i hope someone can help
I am a reseller and the problem is with P5gd1 and external usb hard drives.
Sometimes they work, but after 2 or 3 windows restarts, or after unplugging
and replugging i have the following error:
unknown device
same problem with other external usb hard drives and memory pens...
I CHANGED THE BOARD 2 TIMES, THIS IS THE THIRD!!!!!
the only thing I'm thinking of now is changing the m/b and getting another
one, but not Asus.....
the OS is XP Sp2, formatted at least 10 times, i think i tried
everything.... same problem on rear usb ports, case front ports, rear ports
attached on the m/b....
they are recognized a couple of times, then crack! even after a simple
reboot of windows
unknown device
please help me, i'm loosing money and so much time!
thanks
In article <B03fe.868302$b5.38424671@news3.tin.it>, "Atletiko"
<Atletiko@nospam_libero.it> wrote:
> hi to all
> unknown device
> reboot of windows
> unknown device
> thanks
It could be a software problem.
http://support.microsoft.com/default.aspx?scid=kb;en-us;870893
This site shows how to remove USB entries in the Device Manager
while booted in Safe Mode. It is possible that after doing this,
the external USB hard drive will again be detectable.
http://www.usbman.com/Guides/Cleanup%20Device%20Manager%20Safe%20Mode.htm
If the USBman procedure restores USB operation, then you should
be talking to Microsoft support.
HTH,
Paul
