I ordered a P6N off of NewEgg a couple of weeks ago. When I got it and hooked it up, it did nothing. It wouldn't beep, it wouldn't put out video; nothing. Even if I removed the CPU, RAM, everything, it would react the same. The only thing it did was light up the 4-led thing with the 2 USB ports on it: all 4 lights would go green (indicating OS is booting).
So I figured it was bad, so I returned it and got a replacement.
My new one also does nothing. It acts the same way as the last one, only this time the 4-led panel doesn't light up at all (each LED should light up red or green).
I've thought that maybe the CPU is bad, but I figured the mobo would beep or flash a certain code to me saying the CPU is bad.
Does anyone have some advice for me?
My setup:
P6N mobo
E6600 processor
2x1GB Kingston KVR533D2N4K2/2G DDR2 RAM
EVGA 8800 GTS 640MB
Ultra 20/24-pin 500W Power Supply ULT31841
an ide harddrive, a sata harddrive, and a sata dvd-burner
My setup:
P6N mobo
E6600 processor
EVGA 8800 GTS 640MB
