I recently completed my build and loaded up Windows 7 Beta since it was the closest free OS I had here at work. My plans for this build was to obviously OC my i7 920. A friend of mine essentially has an identical build except he used the Thermalright 120 or whatever it is and he runs at 3.8Ghz. All of my idle temps appeared to be within an "acceptable" limit. I didn't tweak anything in the BIOS yet so things are still at Auto.
I am using the latest version of Prime 95 and Realtemp. I will only be using my build for gaming so nothing crazy. My idle temps are around 40-45C which didn't seem awful. But when I fire up Prime 95 im sitting at around 74-80C at stock speeds? I guess Realtemp records the CPU running at 2.8 Ghz but still. Am I looking at a reseat of my V8? To be completely honest I don't really know anything about OCing so I didn't even attempt to mess with it I was going to have my buddy help me with that. But with my temps already around 74-80C at stock speeds I can't help but wonder if something is really, really wrong here. I applied the thermal paste (AS5) with the "spread it with a credit card" method and tried to get it even.
Also when torture testing with Prime95 I noticed these 74-80C temps only when I run the test that states (max power and heat). When I run the blended test or the other one my temps will typically fall into the 70-75C area. At one point I was curious and removed the side door off my Antec 900 case and applied some pressure to the top of the V8 and the temps dropped about 5-10C? Again forgive me as this was really my first attempt at a custom OC build with aftermarket cooler but in all the years i've been working on computers and building my own i've never had an issue with a cooler not seating right but I guess there is a first time for everything. I've always ran stock speeds on my processors so always ran the stock coolers but I wanted to really get as much performance as I could out of the 920 so I went with the V8 cooler to help with my temps.
What temps should I be expecting to see for idle and 100% load? I was hoping to land my 920 at 3.6Ghz by the time it was all said and done. My friend that runs at 3.8Ghz was saying at times during the torture test he was in the 80-85C area but I don't really feel all that comfortable running that high......
Any suggestions from the pros on what I should do to get my temps down? What about proper thermal paste application to the i7's? Thank you very much ahead of time for your help and thoughts!
My build:
Antec 900 case ( I feel that the airflow in this is sufficient?)
ASUS P6T motherboard
Intel i7 920
Corsair XMS3 DDR3 1600
2- Western Digital 150GB Velociraptors
EVGA GTX260 Superclocked edition
Cooler Master V8 CPU cooler
Antec 650W Neopower supply
My build:
Intel i7 920
