P6VEMD Audio Does not Work
Jerry
1,812
Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
Has anyone else used this motherboard? I bought 3 of them to use with
several fcpga / fcpga2 processors that I had laying around. The driver
Cd has (6) different sets of (audio) drivers with it and none of them
work.
> use with
> The driver
> of them
> work.
I had the Same EXACT Problem with those Board
I search a lot and What Function is to put the Driver From the
Compagny Realtek because it’s a ALC201a Realtek Chipset
http://www.realtek.com.tw/downloads/dlac97-2.aspx?lineid=5&famid=12&series=8&Software=True
Go ther and Take the appropriate Driver
I Also Had to Put 2 JUMPER in The AUDIO1 Section on The Board.
I can’t figure Why it’s not on the MOBO !
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/Elitegroup-P6VEMD-Audio-Work-ftopict51302.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=256145
Where in that section have you put those jumper.
Thank you
On 18 Apr 2005 16:05:10 -0400, wishnight
<DoNotEmail@HardwareForumz.com> wrote:
I installed the jumpers on pins 5-6, and 9-10.
>Thank you
