Hi all , any time i've had a pc problem i've always used this site, and found it to be the most helpfull on the net for troubleshooting and reviews, so i'm really hoping you guys can help me with a problem i'm having.
I'll start with my system specs:
asus p7p55d skt 1156 (xtreme version)
intel core i5 760 2.8ghz
zalman CNPS9500A LED cpu cooler
2x 2gb corsair xsm3 1600MHz 9-9-9-24
xfx hd 5770 xxx
2x raptorX in raid 0 (win 7 ultimate 64bit)
1x wd green 1tb
cit gold 750u
my problem is that the system was working perfectly with no prior issues whatsoever, untill I left it for a few hours the other day.
All that was running was diskeeper.
I came back and the system was turned off.
now the problem i'm having is when I turn it on it just hangs instantly, no post, the fans (gpu especially) are running at 100% the p7p55d memtest red led is brightly lit and the cpu led is dimly lit. If I press and hold the memtest button it just goes from solid to constantly blinking and the cpu led stays dimly lit. the green power light at the bottom of the board is always on. No matter what I do nothing changes.
In my troubleshooting efforts, I have reseated the cpu and checked for damage to pins or contacts, I have reapplyed cpu paste and repositioned the cooler, I have reseated the ram (in the blue slots and made sure they were properly seated) and tried them one at a time, I have tried the motherboard on its own working up adding thing one at a time with no changes in the led situation whatsoever other than randomly one time the cpu light was brightly lit. I have removed the cmos battery numerous times, and i have tried everything I can think of still with no change
now the problem is going to be ram, cpu, motherboard or psu.
I need to try and find the culprit before i spend any money because unfortunatelly it is tight at the minute.
one thing i do know is the psu is pretty crap.
any help or advice would be greatly appreciated.
thankyou.
xfx hd 5770 xxx
1x wd green 1tb
cit gold 750u
thankyou.
