p8z77-v lx mobo fan connectors
smallPAUL
33
Hi, i'm wondering if anyone could tell me where the cpu fan, power fan, chassis 1 and 2 should be connected on this mobo, up in the top right of the board there is a 4 and 3 pin connector, the cpu is connected to the 3 pin and running at 4500rpm the 2nd chassis is in the 4pin connector but only got a 3 pin on the fan, and it is always on, the bottom left two are the same, i got the h60 cooler fan connected to the 1st bottom left connector and the chassis 1 fan connected to the 2nd, the power fan is running at 1036 rpm, the chassis fan 2 is running at 745 rpm and the chassis fan 1 is running at 1134rpm, my mother board is on 25 c idle and 26 c on the browser and the mobo is 21 c,,maximum, after changing things, all my fans are on full power, but silent, my pwr fan is running at 4600 rpm, my cpu is running at 1042 rpm, my chassis 1 fan is running at 776 rpm, and my chassis fan 2 is running at 735 rpm, since i have done this the two chassis fans are running round equally and are less noisy, as before i changed it, one was noisier than the other, my cpu is at 26c idle and my mobo at 21 c idle, if i put the power fan where the cpu fan is now, it makes a lot of noise, could u tell me if i corrected the fan connectors in the right place, thankyou
