[SOLVED] Pages take up to 10 seconds to load after Power Outage
Nov 29, 2019
6
I have a pc that is connect directly to the router with ethernet cable.
My internet speeds are : 25ms/35down and 5up
All the devices that are connected to the internet are working perfectly expect mine
When i join a game or talk to the discord my ping is normal and my download speeds too but when i try to google something or join directly a page its taking up to 10secs to load
i tried to disable java on browsing,antivirus even start my pc to safemode but nothing changes
Also my dns on ipv4 is 1.1.1.1/1.0.0.1 and on ipv6 2606:4700:4700::1111/2606:4700:4700::1001 i tried changing them but nothing changes
PCspecs:
OS: Windows 10 Home
Motherboard: ASRock AB350 Pro4
PowerSupply: Corsair RMx White RM750x
Ram: Corsair Vengeance LPX 16GB DDR4-2133MHz
Gpu: Gtx 650 Ti Boost
Cpu: Amd Ryzen 5 2600x
Ralston18
Are you able to log into your router's admin screens to view and change the router's configuration? That is what I mean with respect to changing settings.
Windows 10 has built-in troubleshooters.
Access by using the "WIN" + "I" keys and then > Update & Security > Troubleshoot.
Another way to have Windows find and fix corrupted files is to run "sfc /scannow" via the command prompt.
https://www.lifewire.com/how-to-use-sfc-scannow-to-repair-windows-system-files-2626161
"dism" can also be used.
https://www.windowscentral.com/how-use-dism-command-line-utility-repair-windows-10-image
If you are not comfortable with either of the above links, feel free to do additional research to learn more.
Do avoid any third party software that offers to download or perform such functions.
Ralston18
Update your post to include full system hardware specs and OS.
It may be that your computer is not fully capable of supporting the games, discord, browsing, and so forth.
DNS: Try Google - 8.8.8.8 and 8.8.4.4
Who manages your network router? The router's logs (if available and enabled) may provide some clue as to what is happening. You will need help from whomever manages the router.
As for power outages remember that a sudden unexpected loss of power does not permit the computer to properly shut down.
Files being written to the drive may not be complete or may be corrupted.
If you have Windows 10 then run the built-in troubleshooters. The troubleshooters may find and fix something - a corrupted file perhaps.
Nov 29, 2019
6
i already tried the google dns nothing changes. If you mean if i can change settings in ISP settings by myself yes i can
Also how i can fix the corrupted files if there are any
Ralston18
Nov 29, 2019
6
I tried the windows troubleshooter but nothing, all good also with sfc /scannow too.Nothing wrong
Yes i can change router's configuration
Ralston18
One more: "ipconfig /flushdns"
Reference (Use the Windows 10 section).
https://geeksadvice.com/flush-dns/
Try using another known working ethernet cable.
You can also open either Task Manager or Resource Monitor to observe system performance.
( Note: When working with Task Manager take a look at what all is being launched at startup. There may be some buggy app trying to backup, update, or "phone home".)
Boot your system and open one or the other - not both at the same time.
Do not immediately join a game or use discord. Simply watch what the system is doing for a few minutes. Explore the tool and learn your way around in order to understand what information is being presented. You can sort the columns by clicking the column headers. Right-clicking an entry may provide more details.
Drag the window to one side or the other leaving it open to watch. Go to a gaming site. Look for some change in the monitored window. Game for a few minutes while continuing to watch.
Then open discord and continue your observations.
What you are looking for is some change in the system's parameters that corresponds with the slow loading/performance.
Nov 29, 2019
6
Soo i tried
Soo i tried the flushdns but nothing changes.
about the ethernet cable im going to search for other one (i dont remember where's my old one).
Edit: I fixed it, i ran the following commands:
dism /online /cleanup-image /restorehealth&sfc /scannow&pause
and
netsh winsock reset
Thanks for your time.
