Hello, awhile back I bought the thermal-take core p3 and the color has always bothered me and has been eating away my soul every-time I look at it. I have a dark grey case that doesn't match my white, gold, silver components. I'm experienced with using spray paint, but only on canvases and paper and have little to no idea of what types of paints or primers to use on a metal case. I'm looking for a silver or white sparkly/metallic finish similar to that of the MSI titanium motherboard. I'm also planing on paining my corsair Dominator Platinum if possible. PLEASE HELP!!!
I was also wondering if the following paints would work with the case and/or ram, if not I would like to see if there are any other options similar to this in style.
https://www.amazon.com/dp/B01KG7ILZC (Favorite)
https://www.amazon.com/dp/B00B4GQCLU/ref=wl_mb_recs_1_title
https://www.amazon.com/Rust-Oleum-267734-Glitter-Spray-Silver/dp/B00B4GQD1E/ref=pd_sim_60_1?_encoding=UTF8&psc=1&refRID=YYPTAJQ6V8WBJ236Q4C3
https://www.amazon.com/dp/B000QD3GPW/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23C4Z31E3Y776&coliid=I1DQRETQKTF9H4&psc=1
My components include a white 360mm alpha-cool radiator, white ek CPU block, and a Bits-power white d5 pump with silver fittings. My motherboard is the z170a MSI MPower Gaming titanium with corsair ddr4 ram.
