Pairing 2666mhz with 2400mhz?
sahaj_pal
21
I wish to pair ADATA XPG Z1 8GB RAM STICKS. The one that I have currently is 8GB @ 2666. But I am forced to buy 2400mhz same model due to non availability of the former in my region. So I want to know whether this combo will work perfectly or not?
Also, will both my RAMs now run at 2400?
Matching the specs as close as possible helps the odds but it still may not work. If you want 100% garantee ram is going to work together you'd need to buy kit of how much ram you are wanting, to replace what you currently have.
Hey thanks for your reply. What do you mean by difference of specs mate? I am buying same RAM stick of the same brand, of the same model/nomenclature. Can specs differ in such cases too?
