Palit Geforce GTX750 Ti StormX Dual 2GB GDDR5 or zotac GeForce GTX 750 Ti?
solistics
Commendable
Mar 14, 2016
Hi. I have a motherboard asus P8H67-M evo. Im wondering if Palit Geforce GTX750 Ti StormX Dual 2GB GDDR5 or zotac GeForce GTX 750 Ti is better fit for my motherboard. I know nothing bout clock speed.
Is it advisable to get the palit card and change my motherboard 2 years from now or to get a same clock spd zotac card and change my motherboard 2 years from now? Any advice pls. Thanks!
Both of these cards will fit in the PCI slot on your motherboard, so providing they fit in your case (I don't see why they wouldn't) get whichever one you think looks the best.
I would suggest though that you save up and get a slightly better GPU, whilst the 750Ti will run a decent amount of games at 1080p low/mid settings, it won't be able to run any at super high settings and the 2GB memory will become a limiting factor fairly soon. Saving up for something like a gtx 970 or higher (or even waiting for the new pascal gpu's from nvidia) might be a better option. Of course if you can't wait the 750Ti should do you just fine for now.
