I recently purchased a used Palit Super Jetstream GTX980 on eBay. It installs fine and the drivers go on no problem. It runs 3D games and benchmarks without artifacts but I felt the performance was lacking for a still fairly powerful GPU. So, I opened GPU Z while running a benchmark and noticed the clock speed way below what it should be. As you can see here: http://www.palit.com/palit/vgapro.php?id=2427&lang=en&pn=NE5X980H14G2-2042J&tab=sp , it should be able to boost up to at least 1304MHZ, yet it fluctuates between 700MHZ to around 830MHZ depending on the loading with heavier benchmarks like Superposition in 4K dropping it to low 700s and Heaven letting it go up to 830ish.
I did notice that the power setting in Nvidia control panel was at an energy saving setting (“optimal” I think) so changed it to max performance. This did allow the GPU to run at the full speed when idle i.e. in Windows and 2D apps and games, but it drops down again as soon as any 3D load is applied. GPU Z shows the performance cap reason as being constantly PWR (power green bar) and never changes, but what does that actually mean? Not enough power from PSU? or a problem with the power circuitry on the card?
The temps remain in the 60s under load maxing at around 68C. However, the card does have a rather odd quirk with the fans in that when under load they don’t spin smoothly, they spin up then stop over and over. They aren’t obstructed and can run normally as they do when the PC is first turned on and do when exiting the benchmark. The card has fan stop technology so they don’t spin for normal 2D loads, could this be somehow malfunctioning?
Please advise on what could be doing this and things I could try to fix it?
