Hiya I bought a Lumix DMC-FT5 a week ago and since then the flash has gone and it keeps rejecting my SD card also after I take a photo it makes a high pitched sound and the screen just looks like a bar code please help
rgd1101 nailed it. Return it. If you bought it used, contact the seller. If the seller tells you to go jump in a lake contact Panasonic. There is no simple fix for a camera with as many problems as yours.
