Hello, I am very new to building computers and I plan on building my own computer by the end of 2013. I've done a decent amount of research and I picked out some parts that I'm considering to use. The system I will try to build is intended to be a gaming PC. I need to know whether or not these are all compatible because I'm not 100% confident. It would also be nice if I can get some advice and suggestions for better and/or cheaper parts to be used as an alternative to my originally chosen parts. (I'm not confident that I picked the right Power Supply and Motherboard)
Chosen parts:
CPU: AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core
Motherboard: ASUS M5A99FX PRO R2.0
Hard Drive: Seagate SV35 Series ST1000VX000 1TB
Power Supply: CORSAIR CXM series CX600M 600W ATX12V v2.3
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM
GPU: Nvidia GeForce GTX 660
Case: NZXT SWITCH 810 White CA-SW810-W1 Steel / Plastic ATX HYBRID Full Tower
Optical Drive: ASUS DRW-24F1ST
Thanks to anyone that provides an answer
Chosen parts:
