Question Part picking help for new build.
Blackflag8
4
Hey all, I'm looking into building a new PC and have little knowledge in doing so but have been doing a bunch of research on it. So I'm thinking my build will include a Nvidia Rtx 3060ti maybe up to a 3080 of some sort which I know changes things a bit. I'm looking at the Amd Ryzen 9 5950x cpu. I'm looking for recommendations for a good motherboard to pair with these two. I would like to have one with wifi and Bluetooth capability. Or if there is a cheaper or better way to include Bluetooth in the build I'm open to other options. If anyone has better recommendations for other components too I'm open to all suggestions. Thanks!
I'm in the US, budget is $1500 give or take, no parts to reuse and working with a 144hz, 1080 monitor for not not planning a monitor upgrade in this budget but will upgrade it in the future.
Reactions: Why_Me
https://www.newegg.com/p/2AM-000Z-000A7
LIAN LI LANCOOL 216 X B Mid Tower Computer Case $99.90
https://www.newegg.com/corsair-rmx-series-rm750x-cp-9020199-na-750w/p/N82E16817139271
CORSAIR RMx Series (2021) RM750x 750W 80+ GOLD Modular Power Supply $99.99
https://www.newegg.com/gigabyte-z690-aorus-ultra/p/N82E16813145344
GIGABYTE Z690 AORUS ULTRA $199.99
https://www.amazon.com/dp/B0BCDR9M33
Intel Core i5-13600K $300.00
https://www.amazon.com/DeepCool-AK620-High-Performance-Dual-Tower-Dissipation/dp/B09CSXS3X4
DeepCool AK620 CPU Cooler $64.99
https://www.newegg.com/corsair-32gb-288-pin-ddr5-sdram/p/N82E16820236828
CORSAIR Vengeance DDR5 5600 32GB (2x16GB) CL36 $144.99
O/S SSD
https://www.dell.com/en-us/shop/pny...256-bit-aes/apd/ab142382/storage-drives-media
PNY CS2130 500GB M.2 PCIe NVMe Gen 3 x4 SSD $41.99
Storage SSD
https://www.bhphotovideo.com/c/prod...es_m280cs2130_2tb_rb_2tb_cs2130_nvme_m_2.html
PNY CS2130 2TB M.2 PCIe NVMe Gen 3 x4 SSD $124.99
https://www.amazon.com/dp/B09BK9X9K9
MSI GeForce RTX 3060 Ti Ventus 3X OC 8GB Graphics Card $429.99
Total: $1506.83
https://shopsoftwarekeys.com/shop/microsoft-windows-11-home-32-64-bit-usb-box-pack-1-license/
Microsoft Windows 11 Home 32/64-bit USB $72.99
A better look at those components.
https://lian-li.com/product/lancool-216/
https://www.gigabyte.com/Motherboard/Z690-AORUS-ULTRA-rev-1x#kf
https://www.tomshardware.com/reviews/deepcool-ak620-review
https://www.intel.com/content/www/u...-24m-cache-up-to-5-10-ghz/specifications.html
Something like this for gaming the Cooler is on Amazon for 36 bucks.
AMD build WIFI and Bluetooth 5.2
PCPartPicker Part List
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor ($204.00 @ Newegg)
CPU Cooler: Thermalright Peerless Assasin 120 SE 66.17 CFM CPU Cooler
Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI ATX AM4 Motherboard ($196.99 @ Newegg)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($114.99 @ Amazon)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($179.99 @ Amazon)
Video Card: MSI GAMING X GeForce RTX 3060 Ti LHR 8 GB Video Card ($439.99 @ Amazon)
Case: Fractal Design Pop XL Air ATX Full Tower Case ($110.92 @ B&H)
Power Supply: Corsair RM750x (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM - DVD 64-bit ($107.99 @ Other World Computing)
Total: $1454.86
Generated by PCPartPicker 2022-11-20 18:10 EST-0500
Both above are nice pc's to have, think i could get some more performance out of the gpu with AMD,
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor ($181.54 @ Amazon)
CPU Cooler: Thermalright Frost Commander 140 BLACK 95.5 CFM CPU Cooler ($61.49 @ Amazon)
Motherboard: MSI MPG X570 GAMING PLUS ATX AM4 Motherboard ($146.99 @ B&H)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($114.99 @ Newegg)
Storage: PNY CS2140 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($42.99 @ B&H)
Storage: PNY CS1030 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($119.99 @ Best Buy)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 16 GB Video Card ($499.99 @ Amazon)
Case: Fractal Design Focus 2 RGB ATX Mid Tower Case ($70.98 @ Newegg)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($79.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM - DVD 64-bit ($99.99 @ Newegg)
Wireless Network Adapter: Gigabyte GC-WBAX200 802.11a/b/g/n/ac/ax PCIe x1 Wi-Fi Adapter ($39.99 @ Amazon)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan ($9.25 @ Amazon)
Total: $1477.43
Generated by PCPartPicker 2022-11-21 08:45 EST-0500
If i could push your budget could i by losing the smaller ssd even get a for gaming better cpu out of it,
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor ($359.00 @ Amazon)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($92.99 @ Amazon)
Total: $1589.90
Generated by PCPartPicker 2022-11-21 08:47 EST-0500
I did use a cheaper case which i think is still fine for these parts (added two fans to put in the back which makes it more xpensive again though,maybe one is enough) , the big cooler is really necessary for the 5800X3D, the 5700X could do with a smaller one.
Did look at this motherboard,
https://pcpartpicker.com/product/QV...atx-am4-motherboard-x570-steel-legend-wifi-ax
it does come with WIFI but cannot say for sure it comes with the latest bios, the one in the builds above supports USB Bios Flashback which makes it easy to update the bios in case of incompatibility.
Oh if Nvidia is your thing, this is also possible,
https://pcpartpicker.com/product/Zc...2x-oc-video-card-rtx-3070-ventus-2x-8g-oc-lhr
Since pcpartpicker isn't showing what AM5 does some suggestions from one Newegg, but Amazon and other shops (maybe a Micro Center nearby?) should also sell these,
cpu's,
https://www.newegg.com/amd-ryzen-5-...cription=am5&cm_re=am5-_-19-113-770-_-Product
or
https://www.newegg.com/amd-ryzen-7-..._re=am5-_-19-113-768-_-Product&quicklink=true
motherboard,
https://www.newegg.com/asus-tuf-gam...cription=am5&cm_re=am5-_-13-119-595-_-Product
or,
https://www.newegg.com/msi-pro-b650...cription=am5&cm_re=am5-_-13-144-560-_-Product
ram,
https://www.newegg.com/team-32gb/p/N82E16820331839
especially motherboard is more expensive, but it does have wifi so the added $40 wifi card on the builds can be taken out.
