Partition Resize Went Wrong, MFT & MFT Mirror Damaged
Heeltoeclutch
Commendable
Sep 22, 2016
Hello all,
I am hoping you can assist me, and thank you very, very much in advance.
I own a Samsung Chronos laptop with a 1 TB harddrive. I originally partitioned the HDD into 250GB C: for programs, 500 GB E: for Media, and left the remainder (approx 150 GB) between the two (D:?) so that I could ration it as needed for whatever filled up first.
Media filled up first. So, a few days ago I opened AOMEI Partition Assistant Standard Edition, and tried to allocate 50GB to C: and the other 100GB to E:.
C: went fine, and it's bigger now. However, an error popped up, which I stupidly did not record, saying something happened during E:, and next thing I know my computer looks like this:
E: Media is damaged. In AOMEI it looks like this:
This is bad. I research and find TestDisk and PhotoRec. TestDisk tells me that E:'s MFT and MFT Mirr. are damaged. I run PhotoRec for 9 hours, and it finds a ton of files, all renamed of course. Hundreds of these are Adobe files, which cannot be previewed in Explorer, and would take weeks to sort through and rename.
I would very much like to recover this partition and/or files with names, if at all possible. I have bought an external 1 TB and used AOMEI Backupper Standard to create a Sector-by-Sector clone of E: so that I may try to fix it without bothering the original. I have read about a few softwares like R-Studio and DMDE to try, but I also read that running certain softwares on damaged sectors/disks can be harmful; as such I want to check with you knowledgeable folks before proceeding further.
Thank you so much everyone in advance; if we can get this data back, and anyone is in San Diego, I owe you several beers!!!! :)
Well first off let me say congrats on being smart enough to buy another drive and do a sector by sector clone of it to mess with!
One other program i like is Power Data Recovery (Now Mini Tools) it can recover files (With names intact depending on the damage to the partition is) and you can export the whole file structure and all.
+1 for Minitool.
Thanks for the tip drtweak and Meepster; I will start checking out mini tools. The cloning idea was not mine, but a smart IT friend.
Mini Tools poses no risk to the data?
Not as far as I know, and I have used it on well over 10 drives.
Got it, thank you. Downloading it now, and will start running it shortly. Going to run it on the external copy, and have it dump data to another external.
For my own understanding - did I do something stupid? Are you not supposed to leave unallocated space between partitions? I have always believed that adding free space to partitions is not a particularly dangerous thing to do...?
Latest posts
