Partitioning HELP!
CuRsEE
22
I'm running windows XP X64 and I need to partition some stuff that I already have on my HD, I need to partition something that's just over a hundred gigs, and I only have 46 gigs of free space . . . I got partition magic but the program doesn't support that OS, I need to do it asap. A little Help please!
thanks in advance!
:twisted: CuRsEE
something over 100 gb? a single file or is it a partition with 100gb of stuff on it?
If it's a file, do a google search for File Splitter and you'll find a bunch of freewares that split the file, create a 3rd small file to parse it back together. I've used them on several occasions.
