Build Advice Parts Compatibility Check and any recommendations/changes ?
Dec 15, 2022
33
Hello,
I was just wondering if all of these components are compatible with one another and if anyone has any recommendations ?
Thank you
Thank you. I'm in the United States and my monitor resolution is 1920x1080. If you have any recommendations, list them and I'll see if my budget allows it
1000W psu is overkill for your build.
https://pcpartpicker.com/product/26...-fully-modular-atx-power-supply-cp-9020200-na
CORSAIR RMx Series (2021) RM850x 850W 80+ GOLD Modular Power Supply $149.99
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=corsair+600w+12vhpwr+cable&_sacat=0
Corsair 600W PCIe 5.0 12VHPWR Type-4 PSU Power Cable CP-8920284 $39.40
https://pcpartpicker.com/product/jR...-fully-modular-atx-power-supply-cp-9020201-na
CORSAIR RMx Series (2021) RM1000x 1000W 80+ GOLD Modular Power Supply $189.99
Corsair 600W PCIe 5.0 12VHPWR Type-4 PSU Power Cable CP-8920284 $39.97
Recommended PSU for that specific MSI 4070ti is 750W, a 600W may be problematic under heavy load.
Not really, its about the same. the Prime has slightly higher ram speed compatibility. I just gave it as an example...
That MSI board is solid.
https://pcpartpicker.com/product/fG...ifi-atx-lga1700-motherboard-prime-z790-a-wifi
ASUS PRIME Z790-A WIFI $309.99
https://www.asus.com/us/motherboards-components/motherboards/prime/prime-z790-a-wifi/techspec/
Memory: 4 x DIMM, Max. 128GB, DDR5 7200+(OC)/7000(OC)/6800(OC)/6600(OC)/6400(OC)/6200(OC)/6000(OC)/5800(OC)/5600/5400/5200/5000/4800, Un-buffered Memory
Audio: Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC
https://pcpartpicker.com/product/8m6p99/msi-pro-z790-a-wifi-atx-lga1700-motherboard-pro-z790-a-wifi
MSI PRO Z790-A WIFI $279.99
https://www.msi.com/Motherboard/PRO-Z790-A-WIFI/Specification
MEMORY: 4x DDR5, Maximum Memory Capacity 128GB
Memory Support 7200+(OC)/ 7000(OC)/ 6800(OC)/ 6600(OC)/ 6400(OC)/ 6200(OC)/ 6000(OC)/ 5800(OC)/ 5600(JEDEC)/ 5400(JEDEC)/ 5200(JEDEC)/ 5000(JEDEC)/ 4800(JEDEC)MHz
AUDIO: Realtek ALC4080 Codec
