was wondering if the NH-D15 will fit in the nzxt h500i case along with the MSI MPG Z390 gaming edge AC motherboard. will all 3 of those parts fit well together? thanks.
tyPer NAXT the case can support up to a 165mm CPU cooler.
Per Noctua with the fan that cooler is 165mm. So it would basically be just within the supported size.
The board should fit fine as thats a standard ATX board and the case fits ATX boards.
I personally would not use that combination since the tolerances are to the exact millimeter. If your cooler is 1mm to long, or your board rests a little higher, you might be pushing up against your tempered glass. Sure, the glass will flex a bit, but then you have a pressure point on the glass AND more pressure on your CPU.
