Parts go good together? + can they handle 1440p + Price in Belgium okay?
yonan_decouter13
12
So i'm going to build my first RIG this summer and i'm not sure if everything is going to good together aka no bottlenecks etc. Second part is if these parts can handle 1440p. At 1080p (21 inch)(€119) i won't be playing at 144hz but probably at 75hz, the same as the 1440p monitor(24 inch)(€199). thx already
CPU: €162: Ryzen 5 1600
MOBO: €76: MSI B350 PC MATE
GPU: €315 MSI GTX 1060 ARMOR 6GB OCV1
PSU: €59,95 CORSAIR CX550 BRONZE
RAM: €159 CORSAIR DDR4 VENGEANCE LPX 2X8GB 2400 C16
CASE: €85,95 NZXT S340 ELITE (WHITE)
and 2TB HDD (€60) en 240GB SSD (€51) and some NZXT 120mm AER RGB case fans & NZXT HUE+ (€72)
Price is €1044,85 in Belgium, for anybody that knows good prices in West-Europe
+ cheapest GTX 1070 is €452 so that isn't an option
All of the parts are compatible. The 1060 is not a 1440p card and it will not be able to push 1440p at 75hz with decent settings. The 1060 is a 1080p/60hz high settings card. For 1440p, you will need to get a 1070.
I also recommend getting higher speed RAM. Ryzen scales well with high speed RAM so I would look for RAM that is 3200mhz in speed.
As for pricing, checkout pcpartpicker.com in your region and it will tell you the current prices for each part.
