[SOLVED] Parts list evaluation
Jul 6, 2019
5
It's been a decade since my last build. Due to space constraints, I'm set on the Node 202 case. This is a work station and gaming console.
I'm sure I haven't hit the performance / price sweet spot on some of these components. Any suggestions are welcome ... especially to make it less expensive.
https://pcpartpicker.com/list/7JmMRJ
I'd not bother with the fans, the gpu will block most of the airflow there and it's almost segmented inside the case. The gpu fans themselves will draw right from the side of the case.
The bar in the middle seperates gpu area from cpu area, there's little airflow between them, that cuts down on much heat transference. The cpu cooler is top vented as is the psu. Not much need for airflow. Standard axial gpus work OK, blower style actually work better in this design, as excess heat isn't recycled through the gpu, it's exhausted out the rear.
You need to post the link with the chain.
They are the slim style fans. According to other builders, there is room between the GPU and the perforated case side to mount the thin fans. Hoping to get more air-flow.
I guess it all depends on the thickness of the GPU.
What are your thoughts?
I'd hold off on those for now and see how the temps are. If anything the better choice for aftermarket cooling would be on the CPU as the stock works well however can get a bit audible but essentially try it first before replacing.
Sounds like a good plan.
Thanks for looking over my build and for your advice.
Reactions: WildCard999
Good point … I hadn't considered that. Makes sense.
Thanks.
