Parts list question
tempest464
17
Hi guys i have a parts list for you to look over and see if anything is incompatible. I've looked quite a bit and no one seems to have this combination but i think technically it should work. just looking for some assurances i guess. so here goes.
Case:Antec 1200 v3: already bought
Cpu: intel i5 6600k:ab
Mobo: Asrock Extreme4 z170:ab
Psu: Antec CP-850:ab
Ram: Hyper X Fury 2X 8GB HX426C15FBK2/16-SLV: Still need to buy
Cpu cooler: Cooler Master v8 gts still need to buy
GPU: Prob a EVGA GTX970 (but that'll have to be bought later on)
Just wondering if everything is compatible with everything else.and i know the cpu cooler is ginormous but it should fit with side cover on according to its specs. but again i haven't really found anyone with this combo. anyway thanks in advance
I wouldn't buy a GTX 970,
They're more expensive (obviously deppends where you live) and worse than a 1060. Get it instead.
Aside from that, great build, shall face no problem whatsoever
Yes i see that now thanks for the heads up: cheers
