Question Parts required for building windows 7 machine in 2020
PHRAZOR
13
I want to build a system that runs windows 7 flawlessly. Please don't turn it into a upgrade to Windows 10 thread. Please list atleast the cpu and motherboard required.
ex_bubblehead
Champion
You'll have to go back a few years to find such a system as newer systems only support Windows 10 (and maybe 8.1). Windows 7 goes "End Of Life" in just over a week which means no more patches or updates. Time to face the facts (whether or not you want to hear it) that Windows 10 is the future.
PHRAZOR
13
Actually the problem with me is that I need Corel 12 for business and Windows 10 does not support it. I cant use latest corel because in the ecosystem I live in everybody uses old version and you just cant survive out of the ecosystem. But at the same time I want a modern Graphic Design machine that can match up to the workflow I have. I am really in a fix what to do.
ex_bubblehead
Champion
Then you (and your "ecosystem") is at a crossroads. Your requirements are diametrically opposed. You cannot have both a modern "Graphic Design" machine and one that supports the old workflow (as you've defined it) simultaneously. Something has to give. Though Windows 7 in a virtual machine just might be usable.
PHRAZOR
13
I was reading about MSI B450 Tomahawk motherboard and it said it supports windows 7 64 bit with Pinnacle Ridge and Summit Ridge CPUs. How does that work?
Blitz Blitz
704
11
5,015
11
Some peoples and companies still use windows 7. It have better compatibility, stability, performance and etc. in some ways, better work with older software(also newer). Not everybody have hundreds, or thousands dollars for new rigs and software. I think best, and newest you can get from intel 6 th gen processors. Also check motherboards, that fully supports windows 7 drivers and features.
PHRAZOR
13
Rather than build a windows 7 machine, I would buy one. With the EOL of Windows 7 coming there are many windows 7 machines for sale on Ebay.
I live in India and eBay shows windows 7 machines at 420 dollars plus 100 dollars shipping. But atleast I will be saved the headache of individually looking for four year old parts. Good option.
PHRAZOR
13
Does Corel 2019 allow you to save as 12?
No Corel draw 19 files do not work on Corel draw 12. This is my biggest headache. I want to work on Corel draw 12 but all the latest hardware doesn't support windows 7 which supports Corel draw 12. I am really in a fix.
PHRAZOR
13
Thanks for the advice. Even 6th Generation processors will be a massive upgrade over my current Core 2 duo. Also Microsoft didn't do good by blocking windows 7 on all newest hardware but nothing can be done now.
Thread starter Similar threads Forum Replies Date
H Windows 7 4
H Windows 7 2
