I am trying to understand why too much paste applied is a bad thing.
Aside from the obviousness of it being wasteful why is it so bad if you have some "squeezeout"
As long as it is not electrically conductive, wont just the use of a couple of q-tips take care of it?
After all, if you get a uniform runout of all sides then you know that it has been completely and evenly spread out over the entire whatsitcalled (die?) right?
