Archived from groups: alt.sys.pc-clone.packardbell (
More info?)
This site gives you some manual information but unfortunately, I don't see
anything about the ability to disable video.
http://www.uktsupport.co.uk/pb/mb/680.htm
However, I have worked on some older PBs (Socket-7 like yours) where I
installed a video card into it. I did not need to set any jumpers. The
computer automatically routed video to the card, i.e. no signal came out of
the onboard VGA connector. I had to further disable (not uninstall) the
onboard video in Device Manager (yours should show up as S3 Trio64V+ or S3
Virge 3D) in order to ensure the proper drivers for your PCI video card
could be properly installed and used.
"Ross Overcash" <jroverca@earthlink.net> wrote in message
news:nbdhe.288$M36.33@newsread1.news.atl.earthlink.net...
> This is great advice, however the viewer.exe file will not run under
> windows XP so I guess I'm back to square one! Is there anyone that knows
> the jumper setings for the on board video so I can take out the no longer
> needed video card
> ross
> "RRR_News" <nospam@isp.com> wrote in message
> news
😱KmdnYWzA4knys3fRVn-pA@comcast.com...
>> Ross,
>> Go to PriorityOne Support website, under the "DRIVERS" section. You will
>> need to register with an email address and password.
>> http://priorityonesupport.com/
>> Tools> Drivers Section> Packard Bell> there you can download what you
>> need.
>> There is a download for the mother board, under manuals, make sure your
>> also
>> download and install the viewer.
>> Rich/rerat
>> (RRR News) <message rule>
>> <<Previous Text Snipped to Save Bandwidth When Appropriate>>
>> news:tdW3e.11420$z.858@newsread2.news.atl.earthlink.net...
>> Seems that I have either thrown out or totally misplaced the manual for
>> this
>> box. It is currently set up as a linux Firewall, I would like to remove
>> the add on video card and restore the on board graphics, however I don't
>> know what the jumper settings should be to restor the on board graphics
>> capability. Anyone have a clue?
>> Ross
