The build I have planned out uses a NZXT H500i, which comes with two 120mm Aer F fans. I don’t know if I should buy an additional pack of Aer F 140mm, or just stick with the 2 120mm fans to slash the price. Would the temps using the stock fans be adequate/good? The included fans are mounted as both exhaust, so I’ll relocate one to the front if I use the stock fans. Also, the NZXT H500i comes with a “3x fan channels with Max 10 watt per channel output”. Could you please explain what this is to me? I’m assuming it allows me to control fan speed PWM or not. On top of all this, yes I’m asking alot, does the H500i have good/sufficienct air flow? Thanks in advance!
Here is my planned build: https://pcpartpicker.com/list/Fhysvn
Any feedback and tips on this build of mine would also be appreciated!
(Excuse if the part selection is bad; I’m a first time builder.)
