PC and PS4 Audio in one headset.
ScaZeD
Commendable
Apr 11, 2016
9
First off I'm not sure where this should go so I'm putting it in home audio because it has something to do with audio. Anyway, I have the Razer Kraken 7.1s, and it's a usb headset. I was wondering is there was a way to have it connected to my PC and PS4 at the same time because I usually skype my friends when I play and I have to have them going over my speakers.
Headsets that connect via USB to a computer usually show up as a dedicated audio device to the computer, so the simple answer is no, you can't add your PS4 audio to your headset. Your headset's audio device would need a method of inputting the PS4's audio and mixing it to your computer's audio output for this to work.
how would i set up a mixer i want to get one but it seems like i need something like 3, 3.5mm to 1/4inch ts.
I would love it if you could help me set up a mixer
