Pc Assembling Help.
Srikanth2013
31
MotherBoard - msi-z97
http://www.snapdeal.com/product/msi-z97-gaming-3-motherboard/614842863
CPU - AMD AM3+ FX 6-Core Edition FX-6300 3.5 GHz
http://www.snapdeal.com/product/amd-44-ghz-am3-fx/1472312774
GPU - R9 270x
http://www.snapdeal.com/product/sapphire-vaporx-r9-270x-2g/2111742387
Power supply - Corsair VS 650
http://www.snapdeal.com/product/corsair-vs-650-smps/509794
Case - Master Elite 431
http://www.snapdeal.com/product/cooler-master-elite-431-w/541758
Ram - Transcend 4gb ddr3 (Already have one so getting one more).
http://www.snapdeal.com/product/transcend-4gb-ddr3-ram-1600mhz/1224206691
Above items good?????? please suggest if you have any good or better items which you know in low price and as more features than above items and suggest if i am missing any item.
Two related sites you might want to play at, PCPartPicker and ChooseMyPC
ChooseMyPC will create a build based on certain criteria (cost, etc.) and PCPartPicker allows you to go crazy configuring systems. While neither site currently have links to PC stores in India, and some parts available to you may not be listed, it does check compatibility as you go so you wouldn't end up with incompatible parts
This one bro??? Msi - 970
http://www.snapdeal.com/product/msi-970-gaming-mother-board/667763636189
Cooler - Heatsink and fan included (Info given at site says Heatsink and fan included, so thats not enough?? does buying new necessary???)
My current RAM's
Latency - 1600 mhz, Bus Speed - (How to Find?) , Voltage Config - (How to Find?).
yes, MSI 970 is a high Quality AM3+ mobo. You can Overclock Fx-6300 even Fx-8350 with that mobo.
Without overclocking stock AMD fan is fine. But AMD FX is meant for Overclocking to see it's true performance. If you overclock with that stock Cooler, the CPU temp will rise up really high.
Better get a i5-4460+B85 mobo.
http://www.snapdeal.com/product/intel-i54440-processor-31-ghz/115595088
http://www.snapdeal.com/product/asus-b85mg-motherboard/1367770960
or i3+H81 mobo
The Ram information you can find in
1. Sticker [that has been attached with RAM]
2. Ram packaging box
3. install CPU-Z
Aftermarket coolers are for overclocking right ??
Why do you go on Snapdeal ?? That site sucks. Look for components on Flipkart. They have everything well organized
Get a better PSU like Seasonic s12ii 520 w/ 620w. I think 520w would be enough
http://www.flipkart.com/seasonic-s12ii-520-watts-psu/p/itmd5xz5hzvzt9cx?q=Seasonic+S12II+520+Watts+PSU&as=on&as-show=on&otracker=start&as-pos=p_2_seasonic&pid=PSUD5XZ4KFH65H9E
And FX 6300 is an old CPU.
@RababNoor Bro see this config -
http://pcpartpicker.com/p/ZR68NG
Ok so if i dont overclock it, stock heatsink and fan is enough right???
and only if i overclock it i will get that (4.1GHz Turbo) ?? if yes then in future i will buy good cpu cooler and overlock it.
and if that processor is getting wasted because i am not overclocking it then suggest me a good processor which suits to that msi 970 board...tyty.
And bro i am preferring that msi board because of its Killer Ethernet feature, i play a lot of online game mainly csgo and dota2 so...
@Adgo, for me snapdeal is more reliable and way better than that shit flipkart so no thx you.
and is that Seasonic a good company?
Seasonic make some serious PSUs. Those are classified as tier 2
See this - http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html#xtor=EPR-8886
* That Build is good but you For Gaming 16GB Ram is Overkill.
* Just get Dual Channel Ram Kit [2x4GB] = 8GB
* With the xtra money get a Cooler : Cooler Master Hyper 212X or Cooler Master 212 EVO
* Get the Seasonic PSU. It will save your GPU in the long run.
Get either Build 01:
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($98.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Directron)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard ($82.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ Newegg)
Storage: Western Digital Caviar Green 1TB 3.5" 5400RPM Internal Hard Drive ($49.89 @ OutletPC)
Video Card: Sapphire Radeon R9 270X 2GB Vapor-X Video Card ($182.98 @ Newegg)
Case: Cooler Master Elite 431 Plus (Black) ATX Mid Tower Case ($51.99 @ Newegg)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($59.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.45 @ OutletPC)
Total: $613.15
Generated by PCPartPicker 2015-10-05 12:19 EDT-0400
or Build 02:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($175.88 @ OutletPC)
Motherboard: Asus B85M-G R2.0 Micro ATX LGA1150 Motherboard ($66.28 @ Amazon)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($54.00 @ Newegg)
Total: $637.46
Generated by PCPartPicker 2015-10-05 12:17 EDT-0400
@RababNoor ok bro going with this config......
http://pcpartpicker.com/p/cX34bv
