[SOLVED] PC at random instance will crash and not operate (not temperature related)
girawott
7
For some reason my PC will just stop being responsive though I can still move my mouse around but nothing more forcing me to power off the PC. The issue can't be related to overheating since the temperature is not hot at all and this happens even when not playing a game
Does it help when anebling DOCP? (profile one, in the bios) That will make your ram run at rated specs which it isn't right now. Shouldn't really matter since spd speed should work, but is an easy to test thing.
Can you test without wireless adapter?
Temps are fine?
open hwinfo,
check "sensors-only",
click "run".
What parts in the pc?
download hwinfo,
install and open it=click run,
close the top window which is the system summary,
in the main window at the left top click "save report",
at the bottom of the next window check "Summary for Clipboard",
after that you'll see what's in the pc,
copy by clicking "copy to clipboard" and rightclick+paste in your next respons
for psu also maker+model+wattage.
CPU: AMD Ryzen 5 2600 (Pinnacle Ridge, PiR-B2)
3400 MHz (34.00x100.0) @ 1546 MHz (15.50x99.8)
Motherboard: ASUS PRIME B450-PLUS
BIOS: 2202, 07/14/2020
Chipset: AMD B450 (Low-Power Promontory PROM26.A)
Memory: 16384 MBytes @ 1064 MHz, 15-15-15-36
- 8192 MB PC17000 DDR4 SDRAM - Corsair CMK16GX4M2B3000C15
Graphics: Sapphire RX 590 Nitro+
AMD Radeon RX 590, 8192 MB GDDR5 SDRAM
Drive: WDC WD10EZEX-08WN4A0, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: CT500P1SSD8, 488.4 GB, NVMe
Sound: ATI/AMD Bermuda/Ellesmere - High Definition Audio Controller
Sound: AMD Zen - HD Audio Controller
Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Network: TP-LINK Wireless USB Adapter
OS: Microsoft Windows 10 Professional (x64) Build 19041.450 (2004/May 2020 Update)
PSU: Corsair, RM Series RM750, and 750 watts
Temps are fine?
open hwinfo,
click "run".
