Pc Audio Issues
Boxer Turtle
My mic picks up all the sound from my headphones when I'm in my pc. It isn't the mic though because I've checked them on other systems. Anyone know a solution to fix this?
you mean you hear everything even your own voice?
Right click the SPEAKERS icon in the right corner. click the PLAYBACK DEVICES. RightClick on the speakers you are using. Choose PROPERTIES
Go into to the LEVELS TAB. Find MICROPHONE, click on it so its get "muted" there..
Check your mic on the teamspeak, skype or something.
Then go to Recording devices, click on the mic, properties and the listen tab. Check what its on under Playback through this device. It should be your default playback devices. And you must have set your speakers to default.
I tried this and it didn't work any other ideas?
