PC auto restart while gaming! HELP!
isaac95
4
My PC specs:
intel core i5-4590 3.3ghz
asus gtx 970
corsair 16gb ram
stock cpu fan
gm750w cm psu
wd black 1tb
hyperx 120gb ssd
It loads the games a little while and when it completes the pc gets restarted!
Can anybody tell me what to do? Any suggestions???
1| You forgot to include the make and model of your motherboard as well as the OS you're on. Please include them.
2| Does this issue crop up only when you game? If so which games have you tried on your system to repeat the issue?
3| Have you made sure your motherboard BIOS as well as your GPU drivers are up to date?
4| From the looks of things it reads out like your PSU is failing. How old is it?
Discover the cause of the restarts.
You can do that by using the Event Viewer logs.
Look for errors codes or warnings just before or at the time of the crash.
You may find Event Viewer confusing but you can do no harm by exploring.
Logs may indicate no data but after a minute or so will present entries. Right clicking an entry will provide more details about what happened.
FYI: http://www.tomshardware.com/faq/id-3128616/windows-event-viewer.html
1|Sorry..it's asus maximus vii ranger
2|i tried such as csgo, tom clancy's ghost recon wildlands and gta 5 but still it's same
3|yes..my bios and gpu drivers are up to date
4|around 2years
Latest posts
