Question PC automatically kills power when CPU reaches 70 degree celsius
May 3, 2019
5
All new parts, just completed yesterday.
GPU benchmark runs fine, but CPU benchmark always fail because as soon as it hits 70 degree the whole pc just shuts down. No blue screen, no restart.
Temperature is about 38 degree when idle, 45 when google chrome is launched, 51 when installing 1 game and running 1 android simulator. All stock, no oc. Using AIDA64 to monitor the temperature.
Ryzen 5 2600
Asrock B450 Pro4
Zotac GTX 1660 Ti
FSP 600W 80+
Stock CPU cooler, 2 intake 1 exhaust.
punkncat
Commendable
Apr 3, 2018
1,270
63
1,540
My Ryzen 1700 does pretty much the same thing. I have read that there is a temperature offset with Ryzen of 20*. Some further confirmation of that might be good. I have never taken a 'heat gun' to it to verify.
May 3, 2019
5
Okay. If anybody is having the same problem, find core performance boost in your bios and disable it.
It can now run everything without problem and the cpu temperature never got beyond 68°C for me.
May 8, 2019
4
OR it might be that some monitoring software has a 20c offset. So while you think its at 70c, its actually at 90c, and reaching T-junction.
from Pg 69 of manual: (Hardware Health Monitoring)
'Over Temperature Protection When Over Temperature Protection is enabled, the system automatically shuts down when the motherboard is overheated. '
Are you perhaps running an AIO, and maybe case fans provide little/no airflow of mainboard's VRM circuitry?
May 3, 2019
5
I'm running the stock cooler on cpu, 2 140mm on the front and 1 120mm in the back. Motherboard is usually 10 degrees cooler than the cpu.
Oh yeah and the shop agreed to change the power supply because the same model they gave me had three similar incidents lately. Sending it back tomorrow to change it and run some tests.
