pc.avdesktop malware removal problems
CrazedRhetoric
9
i have a hijacker malware that i cant get rid of. it doesn't pop up for any of my scanning programs
(malware bytes windows protector, or bit defender) randomly it will open a browser window and say something along the lines of " you may have 13 viruses on your comp....) blah blahbalh..
i would really like some advice on this thing because i cant seam to get rid of it. its not in my firefox add ons. and it don't seam to see it in my task manager or add/remove programs.
im using windows 8.1
Some malware doesn't put its head over the parapet by using malicious software code, so the malware detectors miss them. They don't pick up plain English like "you have a virus" or "buy our lovely product".
Press your Windows key and R together then in Run box that shows up type
regedit
and press Enter.
From the File menu, choose Export then note the name and location of the backup you're about to make just in case anyting goes wrong. It never does but it's wise to back up the Registry.
From the Edit menu choose Find and type in the name of the threat and it Enter. Delete the first one it finds then hit the F3 key to Find Next and delete every entry.
Leave the Registry from the File>Exit menu and go to File Explorer. From the View menu go to Options then Files and Folders. Tick to Show Hidden Files and Folders and untick Hide Protected System Files. Apply and OK then go into c:\users\{youraccount}AppData and delete any references to the threat in all three sub-folders. Do the same in the AllUsers folders.
Few bad things get past you when you've done that.
Open Firefox and in the URL bar, type about:config then hit the Enter key. Accept the dire warning about dragons then enter the name of the threat in the search bar.
Hopefully, any entries you find will be in bold print and can be deleted but post back copies of any feint entries and we'll discuss them later.
extensions.adblockplus.recentReports;[{"site":"pc.avdesktop.com","reportURL":"https://reports.adblockplus.org/380ae95a-b453-4dfa-b2c0-36e0d0dc2683","time":1462368989619}]
so i did that this is the one that pops up when i enter "pc.avdesktop" is this one safe to delete?
what is the difference between the bold printed ones and the non bold?
i didn't see it in either. am i searching for the right thing? ive been searching for "pc.avdesktop" because that is the first in the long url that pops up for me. would it be under something else?
I think you may have a malware on your system that generates ads on your system.If you click on such ads you may end up installing other malware too. To stop this you need to install Ablock Plus ad blocker. The security software blocks such ads and pop ups and keep your system clean. For any more detail refer the link: http://ablockplus.org/about-us.html
123Andrew, I'm 100% in favour of AdBlockPlus in Firefox but it can't work a miracle in retrospect.
CrazedRhetoric, I'd like you to go to this site https://sourceforge.net/projects/hjt/ to download HijackThis. Install it and run the System Scan Only then publish the log here. If there's anything remotely identifiable to you, please remove it.
I'll clean it up further and also analyse it and with the collective Forum brain, we'll get this little ah heck.
I don't think I was confused but anything that names itself so close to an established and highly regarded utility is almost certainly intended to confuse.
It seems to be made for Chrome but so are fifty thousand and some other extensions designed to harvest peoples' personal data and phone it home to Google.
For Firefox and IE, I would stick with the proper AdBlock Plus.
I haven't removed your link but another Moderator might take a different view. We have to consider future readers of this thread who might be taken in by the apparently intended deception.
Logfile of Trend Micro HijackThis v2.0.5
Scan saved at 10:23:59 PM, on 5/28/2016
Platform: Unknown Windows (WinNT 6.02.1008)
MSIE: Internet Explorer v11.0 (11.00.9600.18123)
FIREFOX: 46.0.1 (x86 en-US)
Boot mode: Normal
Running processes:
C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
C:\Users\justin\AppData\Local\Discord\app-0.0.290\Discord.exe
C:\ProgramData\Battle.net\Agent\Agent.4949\Agent.exe
C:\Program Files (x86)\Battle.net\Battle.net.7348\Battle.net.exe
C:\Program Files (x86)\Battle.net\Battle.net.7348\Battle.net Helper.exe
C:\Program Files (x86)\Mozilla Firefox\firefox.exe
C:\Users\justin\AppData\Roaming\uTorrent\uTorrent.exe
C:\Users\justin\AppData\Roaming\uTorrent\updates\3.4.6_42094\utorrentie.exe
C:\Program Files (x86)\Razer Chroma SDK\bin\RzChromaAppManager.exe
C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_21_0_0_242.exe
C:\Users\justin\Downloads\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/p/?LinkId=255141
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/p/?LinkId=255141
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,First Home Page = http://go.microsoft.com/fwlink/?LinkID=226786&Mkt=en-US&Src=WD8&Tid=00033BB0&OHP=www.google.com&OSP=
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = <-loopback>;*.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe,
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre1.8.0_73\bin\ssv.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre1.8.0_73\bin\jp2ssv.dll
O4 - HKLM\..\Run: [Panda Security URL Filtering] "C:\ProgramData\Panda Security URL Filtering\Panda_URL_Filtering.exe"
O4 - HKLM\..\Run: [Razer Synapse] "C:\Program Files (x86)\Razer\Synapse\RzSynapse.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKCU\..\Run: [UM] C:\Users\justin\AppData\Roaming\Update Manager\UM.EXE
O4 - HKCU\..\Run: [EADM] "C:\Program Files (x86)\Origin\Origin.exe" -AutoStart
O4 - HKCU\..\Run: [uTorrent] "C:\Users\justin\AppData\Roaming\uTorrent\uTorrent.exe" /MINIMIZED
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O15 - Trusted Zone: *.clonewarsadventures.com
O15 - Trusted Zone: *.freerealms.com
O15 - Trusted Zone: *.soe.com
O15 - Trusted Zone: *.sony.com
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: Apple Mobile Device Service - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: BattlEye Service (BEService) - Unknown owner - C:\Program Files (x86)\Common Files\BattlEye\BEService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Intel(R) Content Protection HECI Service (cphs) - Intel Corporation - C:\Windows\SysWow64\IntelCpHeciSvc.exe
O23 - Service: EasyAntiCheat - EasyAntiCheat Ltd - C:\Windows\system32\EasyAntiCheat.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: NVIDIA GeForce Experience Service (GfExperienceService) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe
O23 - Service: Bitdefender Antivirus Free Edition (gzserv) - Bitdefender - C:\Program Files\Bitdefender\Antivirus Free Edition\gzserv.exe
O23 - Service: Hi-Rez Studios Authenticate and Update Service (HiPatchService) - Hi-Rez Studios - C:\Program Files (x86)\Hi-Rez Studios\HiPatchService.exe
O23 - Service: Intel(R) Rapid Storage Technology (IAStorDataMgrSvc) - Intel Corporation - C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
O23 - Service: @%SystemRoot%\system32\ieetwcollectorres.dll,-1000 (IEEtwCollectorService) - Unknown owner - C:\Windows\system32\IEEtwCollector.exe (file missing)
O23 - Service: Intel(R) HD Graphics Control Panel Service (igfxCUIService1.0.0.0) - Unknown owner - C:\Windows\system32\igfxCUIService.exe (file missing)
O23 - Service: Intel(R) Capability Licensing Service Interface - Intel(R) Corporation - C:\Program Files\Intel\iCLS Client\HeciServer.exe
O23 - Service: Intel(R) Capability Licensing Service TCP IP Interface - Intel(R) Corporation - C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe
O23 - Service: Intel(R) ME Service - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\FWService\IntelMeFWService.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Intel(R) Update Manager (iumsvc) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe
O23 - Service: Intel(R) Dynamic Application Loader Host Interface Service (jhi_service) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: Mozilla Maintenance Service (MozillaMaintenance) - Mozilla Foundation - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NVIDIA Network Service (NvNetworkService) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
O23 - Service: NVIDIA Streamer Network Service (NvStreamNetworkSvc) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
O23 - Service: NVIDIA Streamer Service (NvStreamSvc) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: Origin Client Service - Electronic Arts - C:\Program Files (x86)\Origin\OriginClientService.exe
O23 - Service: panda_url_filtering Service (panda_url_filtering) - Panda Security - C:\ProgramData\Panda Security URL Filtering\Panda_URL_Filteringb.exe
O23 - Service: Razer Chroma SDK Service - Razer Inc. - C:\Program Files (x86)\Razer Chroma SDK\bin\RzSDKService.exe
O23 - Service: Razer Game Scanner (Razer Game Scanner Service) - Unknown owner - C:\Program Files (x86)\Razer\Razer Services\GSS\GameScannerService.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: Razer Overlay Subsystem Emergency Service (RzOvlMon) - Razer, Inc. - C:\Program Files (x86)\Razer\Core\64bit\rzovlmon.exe
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files (x86)\Skype\Updater\Updater.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Defender\MpAsDesc.dll,-320 (WdNisSvc) - Unknown owner - C:\Program Files (x86)\Windows Defender\NisSrv.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Defender\MpAsDesc.dll,-310 (WinDefend) - Unknown owner - C:\Program Files (x86)\Windows Defender\MsMpEng.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
End of file - 10853 bytes
Sorry but I just caught up with this but don't have the time to do it justice. The Torrent and Discord entries worry me a bit so tick to remove thjose two and restart the computer.
Then run another scan and save it for a few hours and I'll get back to you later but meantime, be careful of any advice you get.
Some forum idiots like to Troll HJT logs and mislead people.
Just got back to the board. why do the torrent and discord entries worry you? Discord is just a chat app. like skype. is there something that i dont know about it? also, what does deleting them do?
Sorry, I took my eye off the ball on tbis one. Torrenting is often used by the wrong people for the wrong reasons. and Discord showed up as being on the borderline and three of them is two too many..
I would definitely get rid of the UM entry in the 04 section of automatic startup programmes. Anything in the 023 section has the ability to "phone home" so are highly suspect if they aren't Windows related.
ok sorry im kinda slow coming back to all this, and im not 100 % knowledgeable about this stuff. i ran hijack this again. and didnt see the UM file you mentioned.
I looked through the 023 section and im not really sure what im looking for in there. What happens if i delete something wrong? Are these files that will really mess stuff up?
also here is the new log
Scan saved at 8:22:52 PM, on 6/13/2016
FIREFOX: 47.0 (x86 en-US)
Boot mode: Normal
Running processes:
C:\Windows\System32\TiltWheelMouse.exe
C:\ProgramData\Razer\Synapse\RzStats\RzStats.Manager.exe
C:\Program Files (x86)\Razer\InGameEngine\32bit\RazerIngameEngine.exe
C:\Users\justin\AppData\Local\razer\InGameEngine\cache\RzSynapse\RzCefRenderProcess.exe
C:\Users\justin\AppData\Local\razer\InGameEngine\cache\RzStats.Manager\RzCefRenderProcess.exe
C:\Users\justin\Desktop\security\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre1.8.0_91\bin\ssv.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre1.8.0_91\bin\jp2ssv.dll
O4 - HKCU\..\Run: [Discord] C:\Users\justin\AppData\Local\Discord\app-0.0.291\Discord.exe
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvscpapisvr.exe
End of file - 10204 bytes
There are a couple in the 023 section that im kind of suspicious of, mainly the ones that say unknown user, but im leery to delete them.
Again thanks for your help
