Question pc beeps and power button flashes but no display?
Dec 3, 2024
5
installed a new gpu (4060) into my system and after, it doesn’t boot it just beeps? i’ve never had this issue and i’ve reset ram and i’ve reset cmos battery, honestly no clue what to do, any ideas?
also the fans ramp up to 100% and then slow down, dk if that helps.
All gpu spin for a few seconds at boot up thats how can tell if they are faulty and then they dont usually work until temps get to around 72.
Count the number of beeps and also look at the code in the small led display and either look in your mobo manual or google what they mean
full system spec? include brand and model of the psu
i5 10400f
rtx 4060
16gb TC 3200 mhz ram
1tb nvme
3tb external hard drive.
it’s a TG01-1020 w a swapped 4060 instead of a 1650.
mobo Model Number L75365-001 L75365-006
Psu L76557-003 (400w)
it’s weird, it’s like 3 slow beeps 3 fast beeps and then that pattern in a row for 3-5 times.
okay so that’s normal then. it’s like 3 slow beeps and then 3 fast beeps and then it does that pattern 3-5 times. if you have any ideas lmk but i couldn’t really find anything. mobo model number is L75365-001 L75365-006
