In short : i bought a ued motherboard that the seller tested before sending and it worked. After i installed it with an i7 2600 and 4gb ram. The fan spins a couple seconds and stops and then spins again en stops, this repeats. I tried reseating the ram, same problem. When i removed the ram, the fans spins and doesnt stop. I think this is a ram problem, but i wanted to make sure. What should i do and try?
