So this post is basically two problems in one but posting together as unsure if related.
The first issue is on boot up my pc seems to be working fine, everything seems in working order apart from no signal is output to my monitor and it stays off, it doesn’t happen all the time but when it does leaving it does nothing so I have to restart and hope it works the next time.
The second issue is on shutdown my pc will close applications, the monitor will go off but then the pc itself keeps running for 5-10 mins and one time it even restarted after that duration.
Any suggestions would be greatly appreciated I’ve already tried multiple things for both some including changing boot timer, turning of the fast startup, disk clean up but none seem to work. If you need any additional info from me just ask
Thanks for your help in advance
